Under Stairs Doors and Frame for Utility Room
McKnze21
by McKnze21 » Mon Sep 28, 2020 7:39 pm
I have knocked out the plasterboard from under my stairs to create a utility room. I now want to fit two doors to close off the under stairs again.
My question, is how do I do this and what do I use exactly? Size & type wood? Screws or Nails? What type hinges? And can I just use like MDF & cut own door to size?
I had originally considers buying fold doors but as stairs are angled I reckon this is too difficult.
My plan is to have a small pull out drawer on runners at one end and then 2 doors at other end. See picture to see how it is now.
Thanks in advance!
Re: Under Stairs Doors and Frame for Utility Room
by stoneyboy » Tue Sep 29, 2020 10:39 pm
Hi mcknze21
Mdf will be ok but you will have to use either T hinges or concealed hinges as used on most kitchens. Either way you will have to instal vertical studs to fix the hinges to.
It is currently Wed Jan 22, 2025 11:54 am
