Roof construction advice after refelting of shed
rob_em
by rob_em » Fri Oct 09, 2020 10:38 am
I had refelting done on my roof. I have noticed that 2 metal profiles at both ends of roof are not secured to the wall only to the rafters. srews fallen out when the roofers were walking on it probably. How important are these profiles for roof to be held in place. thank you
Re: Roof construction advice after refelting of shed
by stoneyboy » Sun Oct 11, 2020 3:00 pm
Hi rob-em
It is not possible from your photo to see what you are referring to but if the roof was originally attached to the wall by metal profiles then they should be re-fixed. This is important with a felt roof where wind lift can be an issue.
It is currently Fri Jan 03, 2025 3:22 am
