Exterior woodstain on interior wood?
MarkGordon
by MarkGordon » Fri Oct 09, 2020 8:02 pm
I was planning on staining the banister on our stairs this weekend, but have realised tonight that I've gone and bought ronseal exterior woodstain.
Is there a reason (finish, fumes etc) that I can't use this stain on the banister?
Re: Exterior woodstain on interior wood?
by stoneyboy » Sat Oct 10, 2020 8:17 pm
Hi markgordon
There is no reason why you should not use an exterior varnish on interior wood. If the wood is new you could use a water based varnish but this will raise the grain leaving a rough surface. If you are re-varnishing it is better to use a solvent based product.
It is currently Fri Nov 22, 2024 3:44 pm
