wise box supply
paultoolbox
wise box supply
by paultoolbox » Sat Oct 10, 2020 2:10 pm
Hello
Bought a 4 way wise box
Connecting 6 outdoor led lights
And a lamppost
Just need to know
Do I run the supply from a lighting supply ( NOT A SOCKET )
I want to run the supply to a fused switched unit
Should I protect with 5amp or 13 amp fuse
Those from this FSU run the supply to the wise box
Thank you Paul
Re: wise box supply
by Mr White » Sat Oct 10, 2020 4:36 pm
The total lamp load for the new lights is? also the total existing lamp load is? The protective device for the existing lights is rated at?
It is currently Fri Nov 22, 2024 4:51 am
