Could gunk in expansion tank cause damage to central heating?
dpw_
by dpw_ » Sun Oct 11, 2020 8:22 pm
Hi - DIY plumber looking for advice.
We have what I think is a Y-plan system, where a single boiler heats the hot water tank and the radiators.
This morning I fitted a new radiator. simple enough, no leaks yet...
Tonight I noticed the CH and water pump was making a terrible noise, and the rads were cold despite the stat demanding heat. I tapped the pipes around the pump, and they sounded empty, and the bleed valve by the hot water tank was not pressurised when I checked there.
I guess that filling the new radiator caused a massive airlock, although where the air came from I have no idea.
The expansion tank in the loft was full of black water, with lots of big globs of gunk. Really gross, like a fish tank overgrown with pond weed.
Despite the gagging, I emptied the expansion tank via a bucket and down the loo, and when I could access the pipe feeding the system, I gave it a 'good fingering' as a make shift plunger. This seemed to release a blockage in the pipework below (judging by the gurgling). I then cleaned the tank and refilled.
The system seems to be working now but I am worried that I have a glob of gunk in the system which will cause an issue down the line.
Do I need to do anything?
Over time we intend to replace a number of rads, I will be cleaning out the expansion tank first next time
Thanks for any advice.
Dan
Re: Could gunk in expansion tank cause damage to central heating?
by stoneyboy » Tue Oct 13, 2020 10:52 pm
Hi dpw_
Suggest you should flush the system, fit a filter (magnatec or something similar) and add system preservative when refilling.
It is currently Tue Feb 04, 2025 12:39 pm
