Access to ceiling above stairs to fit light fitting
Post your questions and get answers on the subject of setting out
Nathsx
by Nathsx » Tue Oct 20, 2020 6:49 pm
Hi all,
After a bit of advice on the best course of action to allow a light fitting to be fitted above our staircase.
I'm hoping for a simple trick of the trade to sort this one if possible.
Basically I need to position something to allow me to stand on it above the stairs to drill into the Truss in the loft. I don't have a issue running the cable nor wiring it up etc, the light itself is fairly heavy and drops about 2.4m from ceiling height.
Here are a few images below :
Image Image Image
The best option i can see so far would be this
https://www.youtube.com/watch?v=zncIahGvkcU
Re: Access to ceiling above stairs to fit light fitting
by stoneyboy » Thu Oct 22, 2020 10:45 pm
Hi nathsx
Suggest you get a 2 part extending ladder the bottom can sit on the higher steps or the top winder and use pads at the top of the ladder to protect the wall.
It is currently Sat Sep 28, 2024 8:24 pm
