Safe Removal of Surplus Hangers?
Martin1946
by Martin1946 » Thu Oct 22, 2020 5:00 pm
I have two vertical 1 1/2" x 3/4" vertical timbers (hangers?) in the centre of my loft connecting two roof rafters at the apex to ceiling joists; what purpose do/did they serve and can they be removed?. It is not a trussed roof; the bungalow was built in the early 60s. and there are similar (shorter) 1 1/2" x 3/4" hangers between the supporting joists and the rafters approximately 6 feet in from the supporting outer walls; there are substantial horizontal beams supporting the rafters running the length of the bungalow supported by external and internal block walls also 6 feet from the external walls. There are no horizontal cross timbers in the loft. The loft is used for storage only.Advice much appreciated. Thankyou
Re: Safe Removal of Surplus Hangers?
by stoneyboy » Fri Oct 23, 2020 7:59 pm
Hi martin1946
More details starting with a picture is needed.
Martin1946
by Martin1946 » Sat Oct 24, 2020 12:13 pm
Thanks for responding to my query.
I have attached four photos as requested.
Photo 1 shows how "flimsy" the wooden post is.
Photo 2 shows where it is attached to one of the uppermost roof timbers which run the length of the bungalow
Photo 3 shows the wooden post from top to bottm; it is attached to thye central floor joist running the length of the bungalow ( The flooring is on loft legs)
Photo 4 shows the shorter side hangers;thes do NOT flex like the two cnetre ones whichcan be moved 1/2" sideways. I intend to leave the side hangers in place.
Thankyou for taking the trouble to reply.
Martin
by stoneyboy » Sat Oct 24, 2020 9:37 pm
Hi martin1946
They are far too small to be structural, the centre ones were probably a temporary support used during construction. The side ones look like a later addition but again not structural.
Martin1946
by Martin1946 » Sat Oct 24, 2020 11:13 pm
Thanks so much for your quick response. It means I can remove the two centre ones. I will leave the side ones as I will be putting some boards up to stop storage items getting pushed onto the unboarded areas.
Thanks and take care.
Martin
It is currently Sun Dec 22, 2024 3:47 am
