Can a toilet pan be connected to a horizontal right angle elbow?
jacob.sumith
by jacob.sumith » Fri Oct 23, 2020 1:15 pm
Horizontal still has 1:40 drop (1 cm for every 40 cm). Please refer to images attached.
But the concern is, as soon as the waste exit from the pan, its going to hit the bend, is this fine?
After exit, the soil pipe runs 11 feet and falls into a clay pipe in the floor. (an old toilet used to be here, floor is concrete)
Does the soil pipe need a vent?
Re: Can a toilet pan be connected to a horizontal right angle elbow?
by stoneyboy » Fri Oct 23, 2020 8:43 pm
Hi jacob.sumith
You should be ok but do not fit a cistern with a reduced or twin flush mechanism.
jacob.sumith
by jacob.sumith » Sat Oct 24, 2020 8:49 am
Thank you.
What would be the best place in the soil pipe to connect a wash basin waste please? (I presume it wont be possible on the elbow, hence it has to be somewhere on the long run)
by stoneyboy » Sat Oct 24, 2020 10:03 pm
Hi Jacob_sumith
Anywhere in the long run will be ok, use a boss strap to make the connection into the top of the pipe.
It is currently Mon Nov 25, 2024 6:33 pm
