new rads
7 posts   •   Page 1 of 1
rezlerken
new rads
by rezlerken » Thu Sep 27, 2007 9:52 pm
:D help have just calculated heat losses in my front room which has always been cold and i estimate i need rads producing 13780 btu's can this right as Iam about to change existing rads any advice mucho appreciated :lol:
rosebery
by rosebery » Fri Sep 28, 2007 8:57 pm
"Can this be right?"
Well it can be.
If it's a standard (sort of) sized semi it seems rather high though for a front room.
What size is the room and how many outside walls?
thedoctor
by thedoctor » Tue Oct 02, 2007 8:16 am
See our central heating projects for help. Central Heating radiators tell you how to work out heat loss accurately and will give you the definative answer.
property man
by property man » Fri Nov 16, 2007 6:43 am
1800 x 700 double required aprox £350.00 plus
rose
Re: new rads
by rose » Wed Nov 05, 2008 11:03 pm
[quote="rezlerken"]:D help have just calculated heat losses in my front room which has always been cold and i estimate i need rads producing 13780 btu's can this right as Iam about to change existing rads any advice mucho appreciated :lol:[/quote]
it all depends on the size of the room. You have to find the cubic size of the room ie height x lengthxwidth and how many outside walls you have. also i think you need the size of anywindows.what you say above does sound alot. Hope this help
Perry525
by Perry525 » Tue Nov 18, 2008 7:59 pm
When you have worked out the size of the radiators, think about where to put them, and how to control them and what the next person who lives in your home may require.
A radiator that can just cope with a rooms heat loss may result in a room that feels cold for someone else.
A radiator that is fitted on an outside wall, will loose a lot of heat to the outside or to the wall cavity.
A radiator fitted under a window will loose a lot of heat, merely warming the window glass.
A radiator where the hot feed enters at the top will give out 15% more heat.
TheDoctor5
by TheDoctor5 » Tue Jan 20, 2009 9:43 am
It is currently Mon Nov 25, 2024 7:34 am
