How to safely remove and disconnect socket
3chrispy7
by 3chrispy7 » Mon Oct 26, 2020 8:01 pm
Hi. I’m after some advice on how to safely remove/disconnect the electrical socket in the attached photo. And depending on this then what to fill the hole in with. It’s been used for an electric fire which we would like to remove. It’s part of the dining room fuse/circuit. Thanks
Re: How to safely remove and disconnect socket
by Mr White » Tue Oct 27, 2020 6:29 am
Your socket appears to have one cable, if this is so, follow it back to where it is fed from, then turn off the electricity at the consumers unit, and disconnect the cable from where it is connected to. Then switch the electricity back on.
It is currently Sun Jan 26, 2025 8:24 pm
