Wiring a mirror with a built in LED light
Harrier1234
by Harrier1234 » Sun Nov 01, 2020 8:22 pm
Going to install a LED mirror light in to WC. Where do I add it into the circuit? Need constant power going to it as the light is activated by swiping underneath..
Re: Wiring a mirror with a built in LED light
by Mr White » Mon Nov 02, 2020 6:21 am
You should connect the light to a constant live neutral and earth, which should be the two blacks (Neutral) and the multiple reds (Live) and the green / yellow (Earth)
It is currently Fri Jan 10, 2025 10:56 pm
