What sealant should I use for my walk in shower tray?
atsgmo
by atsgmo » Wed Nov 04, 2020 8:55 pm
Hi, the flexible grey sealant around our walk in shower is very slightly starting to come away from the edge of the tiles. Should I leave this or will water start to seep underneath? If it needs replacing, which sealant should I use?
It needs to be flexible (rubber-like) sealant as the hard stuff they originally used kept cracking away and they had to use this flexible stuff. But I don't know what it is
Re: What sealant should I use for my walk in shower tray?
by stoneyboy » Fri Nov 06, 2020 10:33 pm
Hi atsgmo
You will need sanitary silicone sealant..
atsgmo
by atsgmo » Sat Nov 07, 2020 10:27 pm
Thank you
It is currently Thu Nov 21, 2024 8:08 pm
