How to locate brick inside a window recess, to fit blinds?
jacob.sumith
by jacob.sumith » Fri Nov 06, 2020 10:01 pm
I have drilled a couple of holes right behind the window and it just went through. Did I drill into the wall cavity?
Instead, if I go just less than 4 inches from the face of the wall, can I guarantee brick (or mortar between bricks)?
I like to set the blind as deep and close to the window as possible. Please advise.
Re: How to locate brick inside a window recess, to fit blinds?
by stoneyboy » Sat Nov 07, 2020 9:51 pm
Hi Jacob.sumith
Chances are that you will have drilled through a cavity closer. Try fixing into the window frame or accept you will need to be away from the window so you can fix into the inner leaf - if your house is masonry construction.
jacob.sumith
by jacob.sumith » Mon Nov 09, 2020 7:58 am
Thanks for the reply.
The fitting provided also includes a bit that can be fitted on the lintel, in addition to brackets that go on the sides, about which I asked the previous question.
Now about the fitting that goes upwards into the lintel, won't this penetrate the cavity tray? and cause water leaks?
by stoneyboy » Mon Nov 09, 2020 10:24 pm
Hi Jacob.sumith
You should not go upwards - you may have steel lintels which will be difficult to fix into.
It is currently Mon Nov 25, 2024 6:48 pm
