Wits end - bathroom trap leaking
Accountantbytrade
by Accountantbytrade » Sat Nov 07, 2020 4:11 pm
I have a brass plug waste and am connecting it to a low profile trap but I can’t stop the trap leaking. It leaks just below the collar. I have tried 4 traps now so I don’t know what to do. Brass waste has ptfe on but not used anything else. It leaks where the arrow is on the picture. Please help. I can’t buy anymore traps!
Re: Wits end - bathroom trap leaking
by stoneyboy » Sun Nov 08, 2020 10:05 pm
Hi accountantbytrade
It looks like you are using a waste with an overflow collar on it and the waste is not long enough, so the trap nut cannot do up enough to clamp the rubber seal.
Buy a longer waste and don’t use ptfe tape, it’s not needed.
Accountantbytrade
by Accountantbytrade » Mon Nov 09, 2020 1:25 pm
Stoneyboy!!!! You are a genius. That's exactly the issue. It won't tighten up enough to clamp the seal together. I tried to put two washers in to help but that was a rubbish idea. Can you recommend a longer waste otherwise I will just have a look next time I am in the shop. Alternatively I could cut it down.
Thanks again!
by stoneyboy » Mon Nov 09, 2020 10:27 pm
Thanks, if you can take the waste out, go to a proper plumbers merchants and select a longer one.
It is currently Sat Nov 23, 2024 1:09 pm
