Options for 50's batten/slab concrete floor - Crumbling & Damp
Mr-Lister
by Mr-Lister » Sat Nov 07, 2020 10:30 pm
Recently bought first home,
Having pulled up laminate & floorboards on ground floor, the floor is concrete slab with wooden battens sunk-in which the boards were fixed to.
The floor has clearly been damp for a long period of time and in parts (exterior wall, where there has been leaks/leaking gutters) is crumbly.
The original battens laid into the floor are totally rotted and in the process of being removed.
My thoughts so far are:
-Sure up the existing floor, fill any big holes etc with new cement.
-Install DPM / Latex screed
-PIR board and Chipboard flooring for new surface.
Particularly stuck on 2 things:
-whether i should leave the channels the battens sat in empty to allow for airflow from airbricks/prevent water pressure if the floor is still damp.
-Where/what layer to put the DPM/screed in - If I lay this directly over the current floor, the screed would be unsupported over the batten channels if I leave these unfilled.
Im totally new to repairing flooring/damp and mainly work with wood - I'd appreciate any thoughts on making the current floor good and product options.
NB, will post some photos of the floor as is over the next few days
It is currently Sun Jan 05, 2025 6:25 am
