Expanding Foam in Cavity Wall Mistake
damyan24
by damyan24 » Mon Nov 09, 2020 5:52 pm
I am a landlord and my tenants experienced issues with damp on the inside of a bay window and it didn't seem like there was an issue with condensation or ventilation (as is usually the case). I noticed a crack where the bay window render meets the brickwork on the outside of the house and thought it may be causing the issue.
I thought I would fill the gap with an all-weather sealant in case this was the cause of the damp. The gap at the top (just above where the arrow is pointing) was fairly big (around 0.5-1cm) so I thought I would use some expanding foam first. Now I didn't realise that the gap was essentially leading straight to the wall cavity so all of the foam just fell down (750ml can). I only then realised it may have actually been a big (and very silly) mistake which could potentially lead to more issues.
I wanted to know if this is something I should worry about and whether there is anything I should do now before I experience any issues with that?
Re: Expanding Foam in Cavity Wall Mistake
by stoneyboy » Wed Nov 11, 2020 9:24 pm
Hi damyan24
The globs of foam in the cavity will not be absorbent so there should be no risk of bridging the cavity, just don’t do it again!
It is currently Sun Nov 24, 2024 10:11 am
