UPVC Windows in an extension and position over cavity
Rossitm
by Rossitm » Tue Nov 10, 2020 8:11 am
Morning all. I’m after some advice on fitting windows in my extension. I read somewhere that the windows need to be 30mm over the cavity? Is this correct? I’ve changed all the other windows in my house and fixed to the inside of the outer brick. Does this mean these are incorrect? Thanks in advance
Re: UPVC Windows in an extension and position over cavity
by stoneyboy » Thu Nov 12, 2020 10:39 pm
Hi rossitm
The installation of replacement windows with the inner face flush with the inside face of the outer brickwork is not wrong. Ideally the windows should be installed to avoid cold bridging but in many cases it is a compromise because replacement windows are shallower than the original. Fitting a upvc strip around the inside of the window overcomes this issue.
It is currently Mon Jan 06, 2025 9:31 pm
