Hopefully the pictures add some clarity to my problem.
I’ve redone my entire bathroom and now on the last part, connecting the WC to the existing waste connector.
To achieve this I’ve purchased McAlpine WC-F26R Flexible WC Pan Connector White 97-107mm which connects onto the WC fine - It’s the other end which is leaking (hasn’t created a tight enough seal). I’ve pushed it into the existing multikwik connector. It’s this part which is leaking.
Any help on getting a tighter seal/fixing the leak would be appreciated.
Thanks in advance!
