Using JG Speedfit on 1/2 Inch Copper Pipe
wildobc
by wildobc » Wed Nov 25, 2020 6:38 pm
Is it possible to use a 15mm JG Speedfit push fit straight coupler directly on to 1/2" copper pipe.
Re: Using JG Speedfit on 1/2 Inch Copper Pipe
by stoneyboy » Fri Nov 27, 2020 1:40 pm
Hi wildobc
Yes but only if you are using a pipe cut by a rotating cutter eg pipeslice.
Suggest you use a small amount of lubricant on the pipe before you insert it, mark the insert length on the pipe so you know it is correctly located.
wildobc
by wildobc » Fri Nov 27, 2020 4:21 pm
Thanks for the advice - will do
It is currently Mon Dec 23, 2024 2:36 pm
