shower valves
bates1966
shower valves
by bates1966 » Sat Sep 29, 2007 10:51 am
HI CAN ANYONE TELL ME IF A MANUAL SHOWER VALVE WOULD WORK WELL ON A CONDENSING BOILER OR MUST I STICK WITH THE MORE EXPENSIVE THERMOSTATIC TYPE
THANKS
STEVIE
Brian Pomeroy
by Brian Pomeroy » Sat Sep 29, 2007 12:21 pm
Hi Stevie
I think you will find that a thermostatic mixer valve can be found starting from around £100 though I have paid less.
The advantges of a thermo are that if your boiler has any problems modulating and thus maintaining a temperature the shower will compensate.
A thermo valve will also have a high temp safey device where you can ensure too high tempertaures are not easily found. A good idea for kids and the infirm.
Other than that a manual valve should work well with a correctly installed and functioning combi.
All the best
Brian
bates1966
by bates1966 » Sun Sep 30, 2007 6:34 pm
Thanks Brian ill stick with thermo then
Cheers steve
It is currently Wed Dec 25, 2024 1:15 pm
