Vapour barrier when Insulating internal wall with sheep's wool?
Martynfaul
by Martynfaul » Sun Dec 06, 2020 5:26 pm
I want to add t&g cladding to an internal wall as a feature but would like to include a layer of insulation as this is an exterior wall and not insulated at all. It is on the first floor which is wood framed above a ground floor of brick construction. I am thinking of using sheep’s wool insulation and my question is do I need a vapour barrier and what is the most worthwhile thickness to use? (up to about 15mm room available) thanks.
Re: Vapour barrier when Insulating internal wall with sheep's wool?
by stoneyboy » Tue Dec 08, 2020 10:02 pm
Hi martynfaul
Yes you must use a vapour barrier but may have to accept condensation forming around the perimeter.
It is currently Thu Nov 21, 2024 7:12 pm
