Insulating redundant chimney with old loft insulation
sapper44
by sapper44 » Wed Dec 09, 2020 8:42 am
Hi thanks for any advice in advance. I have had the chimney removed when I had roof replaced. Its a bungalow so the stack have been removed down to the loft floor level. I have been air sealing the loft floor and replacing and renewing the insulation. I have several bags of old fiberglass insulation. Was wondering if I could use some of this to put in the chimney. I can see the bottom of chimney on one side about 10ft deep. the other side have been opened up and is now an airing cupboard. and is sealed at the top so is about 4 feet deep. To be clear the chimney splits into 2 at loft floor level.
Re: Insulating redundant chimney with old loft insulation
by stoneyboy » Thu Dec 10, 2020 7:04 pm
Hi sapper44
No reason why you should not use it but stick to the current recommended depth of about 300mm. Make sure that your space above the insulation is ventilated.
sapper44
by sapper44 » Thu Dec 10, 2020 7:27 pm
Thank you.
It is currently Wed Jan 08, 2025 6:06 pm
