Is this wiring acceptable?
themoffster
by themoffster » Thu Dec 10, 2020 7:42 pm
I had issues embedding the image, so it is here: https://ibb.co/vBNL08Q
The switched fuse is 13A.
I thought this would work as you are not able to take two spurs off of one socket, so can I spur a switched fuse then have that feed two separate sockets?
If it matters neither will have anything that’s high load (radio, lamps, etc for inside double and speakers for the external for the sunny days).
If this isn’t good could you suggest an alternative way to power the two new sockets from the existing double?
Re: Is this wiring acceptable?
by Mr White » Thu Dec 10, 2020 9:48 pm
You can have as many sockets as you like AFTER the fused connection unit.
It is currently Wed Dec 04, 2024 8:38 am
