Changing bath/shower lever valve
ramrod496
by ramrod496 » Fri Dec 11, 2020 3:00 pm
The valve behind the lever that switches between the shower and the tap outlet needs changing, but I'm not sure how to remove it. Removing the screw doesn't seem to do much. I've wiggled/pulled but no luck. I'm not sure exactly how it works and so don't want to use force and break something. Does anyone know how I can get this lever off to replace the valve behind it?
It is currently Mon Dec 02, 2024 10:32 pm
