Connecting two waste pipes to 40mm waste trap
6 posts   •   Page 1 of 1
Schrodingers Cat
by Schrodingers Cat » Mon Dec 14, 2020 7:51 pm
Hi. I have absolutely no idea what I'm doing so please be patient! Our washing machine waste hose is connected to the waste trap under the sink via a single spigot. The spigot is screwed to the 40mm waste pipe (the waste connector pipe itself is threaded and not a standpipe). We have just got a dishwasher and need to connect the waste pipe so I need an adaptor with a double spigot, but they all seem to be designed for a standpipe and not a threaded connection. Sorry if that was a bit rambling, but like I said, I have no idea. Any help would be appreciated. Thanks.
Re: Connecting two waste pipes to 40mm waste trap
by stoneyboy » Tue Dec 15, 2020 10:39 pm
Hi schrodingers cat
You will have to replace the trap with one with two spigots, McAlpine market one.
Schrodingers Cat
by Schrodingers Cat » Wed Dec 16, 2020 7:28 am
Ok. Thanks for your help
Schrodingers Cat
by Schrodingers Cat » Wed Dec 16, 2020 7:44 am
Are the traps a standard size? If I buy one will I have to cut it to size??
by stoneyboy » Thu Dec 17, 2020 8:22 pm
Hi schrodingers cat
1 1/2" traps are a standard diameter but the height may be different.
Schrodingers Cat
by Schrodingers Cat » Thu Dec 17, 2020 8:29 pm
It is currently Mon Dec 23, 2024 4:29 pm
