Mira Extreme power shower won't turn off!
hoghedge
by hoghedge » Tue Dec 15, 2020 4:13 pm
Hello all. Hoping that someone can help out here . . . Our Mira extreme thermostatic power shower has suddenly decided not to stop when the "stop" button is pressed. I turned it off at the consumer distribution box (if that's the right terminology) and, as expected, the pump and flow of water stopped. When electricity was restored the shower remained off until one of the three power buttons (L/M/H) was pressed, at which point the shower came on as normal - but the stop button again refused to work. Is that sufficient information for anyone in the know to diagnose the fault? Mira's fault-finder suggests a failed microswitch or PCB, but I'm hoping to narrow things down, if possible.
Any ideas/advice will be much appreciated.
Joeb5031
Re: Mira Extreme power shower won't turn off!
by Joeb5031 » Sat Jul 10, 2021 8:02 am
Hello,
Did you ever resolve this issue? We are having the exact same problem with our Mira Extreme. I took the cover off but couldn’t easily access the buttons to have a look.
It is currently Mon Dec 23, 2024 6:17 am
