Installing Concrete Fence posts and Gravel boards on a fence line that has a curving bend.
crilliams
by crilliams » Fri Dec 18, 2020 9:28 am
Hi I would like to install concrete posts and gravel boards along a 27 meter fence line that curves. Can someone advise how I can achieve a curve, whilst keeping the post straight and level. With wooden posts, I guess I would just turn the angle of them sever so slightly, but would this work with concrete posts and gravel boards?
Spuggyfoot
Re: Installing Concrete Fence posts and Gravel boards on a fence line that has a curving bend.
by Spuggyfoot » Fri Dec 18, 2020 9:24 pm
Depends how fast the curve is. They will sit in place on a VERY slight curve. After that you can point/cement the gravel boards in place. A faster curve still and you will need to double up on your fence posts.
Regards, Spuggyfoot.
It is currently Tue Nov 26, 2024 12:02 am
