How To Stop Hot Water Tap Black Bits Debris?
DC4_DIY
by DC4_DIY » Fri Dec 18, 2020 1:34 pm
Hello to All,
How To Stop The Black Bits Coming From The Baths Hot Tap?
Just recently it has been noticed that there have been some ‘Black Bits’ coming from the just the Baths Hot Tap.
This is not noticed when using the Cold Tap or any of the other Taps that are Mixer Taps.
I found an American Post, on another Forum that suggests that it could be from the inside of the Flexi Pipe used from the Plastic Hot Water feed pipe to the Tap.
I believe that this is quite likely to be the source of the ‘Black Bit’ or ‘Particles’ that have started to come out of the Baths Hot Tap.
Are there any Plumbers on this Forum that can confirm or otherwise that the content of this suggestion is true?
Please be Safe and Well during this pandemic Coronavirus uncertainty.
Thank You in advance for your feedback.
Kind Regards,
Daniel > DC4_DIY
Re: How To Stop Hot Water Tap Black Bits Debris?
by stoneyboy » Sat Dec 19, 2020 10:10 pm
Hi dc4_diy.
Have you looked in your cold water tank - this may be the source of your ‘black bits’.
DC4_DIY
by DC4_DIY » Tue Dec 29, 2020 5:31 pm
Hello Stoney Boy and All,
I trust that you had a great Christmas 2020, despite the Coronavirus restrictions.
Moving Forward; I may have been fortunate enough to have resolved to plumbing issues at once.
Both the Bath Tap and Hot Shower Pump feeds share the Hot Water Cylinder outlet pipe.
A few months ago we had our loft insulated with spray foam insulation.
With the assumption that the open top Cold Water Header Tank was covered to stop any debris falling in to it.
After removing the flexible hose to the Bath Hot Water Tap and finding no debris or corrosion, by pulling a ‘J Cloth’ through it, I choose to check the Hot Water feed to the Shower Pump.
Fortunately for me and the Kitchen Ceiling below, I did have a towel to catch the water within the pipe and the Black Bits Debris.
It is assumed that the Black Bits Debris were from the Cold Header Tank via the Hot Water Cylinder.
Following this I removed all of the pipes from the Shower Pump, to find that there was some Debris within the Hot Water Feed Filter.
After cleaning the filter and re-connection of the Hot Water Pipes for the Bath and Shower Pump, there were no more Black Bits coming in to the Hot Tap in to the Bath.
And with about a 90 Degree Turn of the Shower Pump Boost Dial the Shower Pressure has been increased enough to know that you are having a shower…
(For Details Please See Other Thread;
Please be Safe and Well during this Coronavirus Pandemic uncertainty.
Kind Regards,
Daniel > DC4_DIY
DC4_DIY
by DC4_DIY » Tue Dec 29, 2020 5:34 pm
DC4_DIY wrote:Hello Stoney Boy and All,
(For Details Please See Other Thread; HELP Info' Please - Ref; Change Shower Pump To Feel Improved Pressure).
Kind Regards,
Daniel > DC4_DIY
by stoneyboy » Tue Dec 29, 2020 10:18 pm
Hi dc4_diy
Many thanks for the update, good that you have resolved your problems.
It is currently Mon Dec 02, 2024 10:25 pm
