Stone reveal detail with Aluminium Windows
jam11gee
by jam11gee » Thu Jan 07, 2021 4:48 pm
A mason has just put me some new openings in on a conversion project. The reveals aren't flush as it's natural stone, approx 40mm difference I don't want a huge mastic joint at the side of my aluminium windows/doors.
What's the best method to resolve this? Chisel stone down to right size even though they're insitu? Or chop a channel from the inside so the window frame sits in that?
Any other options would be appreciated.
Cheers,
Re: Stone reveal detail with Aluminium Windows
by stoneyboy » Sat Jan 09, 2021 10:29 pm
Hi jam11gee
Suggest you use an angle grinder to cut out a channel the width of your frames and chisel out the centre part. Do a number of cuts down the channel to limit the force of chiselling needed. You may need to fit a narrow sub frame so you can get the windows in.
It is currently Thu Oct 31, 2024 6:14 pm
