Sink tap cleaning and disassembly help needed
hyderon
by hyderon » Fri Jan 08, 2021 9:14 am
Hi Our sink tap is sticking a bit , so I want to investigate
I have taken a small grub screw out,
just wondering if the top should pull off now or do I need to undo something else ( it doesn't seem to want to come off and I don't want to break anything)
Re: Sink tap cleaning and disassembly help needed
by stoneyboy » Sat Jan 09, 2021 10:37 pm
Hi hyderon
The hoop lever is probably fitted onto a square shaft - lever upwards carefully free it.
by stoneyboy » Sat Jan 09, 2021 10:38 pm
Hi hyderon
The hoop lever is probably fitted onto a square shaft - lever upwards carefully free it. Perhaps squirt wd40 into the hole where the grub screw was.
It is currently Mon Dec 23, 2024 3:58 pm
