Fitting bathroom lock existing holes not standard
Czeeczee
by Czeeczee » Sun Jan 10, 2021 11:05 am
I want to fit a lock to a bathroom door. Two holes drilled in door, but only 45mm apart. I was going to use a tubular lock below the handle assembly, but the plates would overlap on the edge of the door, and I can't find a combined one with only 45mm between the latch holes and a 45mm backset! Can anyone help?
It is currently Sun Dec 22, 2024 9:53 am
