Ceiling Rose
8 posts   •   Page 1 of 1
DV
Ceiling Rose
by DV » Sun Sep 30, 2007 6:43 pm
I am installing a new ceiling light so removed the old ceiling rose without noting which wires went where...what can I do?
DV
rosebery
by rosebery » Mon Oct 01, 2007 8:24 am
Look in one of the others perhaps.
DV
Ceiling Rose
by DV » Mon Oct 01, 2007 11:58 am
I am connecting a new light which has a connector block with 4 connections but I have 9 wires coming out of the ceiling - how do I know which one goes where?
I can see that one of the black wires is tagged with a red sleeve indicating that this is the wire for the switch?
any advice appreciated as to which of the 9 wires goes to which of the 4 connectors on the new light
DV
rosebery
by rosebery » Mon Oct 01, 2007 12:55 pm
Same answer as in the other thread. Look at the pic in the project on this site.
by sparx » Mon Oct 01, 2007 4:39 pm
Hi DV, no prob as you have the right sw. wire marked,
the red sleeved blk goes to live of light, the other blks go to the Neutral of light, & all reds go in spare term block not connected to light, this may be the 4th one provided for you,regards
SPARX
sguiggs75
Wiriing Problems
by sguiggs75 » Tue Oct 02, 2007 6:31 pm
Hoping someone can help. I have wired a ceiling rose in the living room had problems with the wires arcing to the fitting but solved now. however this light now works as does the one at the top of the stairs, but none of the others in the house appear to work.
Any help apprieciated
Squiggs :cry:
DV
by DV » Thu Oct 04, 2007 10:00 am
dear Sparx,
by the way, did as you advised and it works perfectly...
thanks for your help, legend...
dv
thedoctor
by thedoctor » Fri Oct 05, 2007 7:47 am
WE have many electrical projects which describe exactly how a ceiling rose is wired. Go to the projects section
It is currently Mon Jan 13, 2025 6:40 pm
