Manrose extractor fan in loft problem
AlanGibbo
by AlanGibbo » Wed Jan 27, 2021 9:18 am
I have a Manrose extractor fan in the loft running through a separate run on timer. Recently when I turn the light on the fan buzzes but does not seem to start or run properly, but when I turn off the light (and the run on timer takes over) it starts fully and runs fine until the timer turns it off.
Its been there for a few years working fine and nothing has changed, just started doing this recently. I've cleaned the inside of the fan. Any ideas ? Thanks
Re: Manrose extractor fan in loft problem
by Mr White » Wed Jan 27, 2021 6:24 pm
It sounds like the timer is starting to fail. (They often do)
You have two choices.
1) By pass the timer.
2) Buy a new fan.
AlanGibbo
by AlanGibbo » Thu Jan 28, 2021 8:57 am
I'll give a new timer a try. Thanks for your help
by Mr White » Thu Jan 28, 2021 7:41 pm
For reference.
A replacement timer is around £12
A replacement fan with timer is £17
It is currently Mon Dec 23, 2024 11:50 am
