Help! I cannot install this light switch into wall - the wall's vertical wood pieces is broken
b274
by b274 » Wed Jan 27, 2021 5:05 pm
Hello all,
I am attempting to install a light switch in my living room, but the horizonal wooden stirps which are behind the wall, is broken directly behind the light switch, thus I have nothing to screw the light switch into, to secure it.
Furthermore, I tried to install a light switch holder (a face place with about an 2" depth (to accommodate the wiring) and i thought this might work because it uses 4 screws to secure to the wall, instead of the 2 in the light switch, but again, the same problem: the screws have nothing to secure to.
Please see the attached photos, for a clearer picture of my problem.
Any help would be greatly appreciated,
thank you in advance
Re: Help! I cannot install this light switch into wall - the wall's vertical wood pieces is broken
by stoneyboy » Thu Jan 28, 2021 8:56 pm
Hi b274
Probably the best chance is to use a deep dry lining box. You may have to use odd bits of timber and expanding foam to secure the box in place.
b274
by b274 » Thu Jan 28, 2021 9:38 pm
thanks for you comment
Can I drill into expanding foam?
by stoneyboy » Fri Jan 29, 2021 10:46 pm
Hi b427
Yes easily but it’s mot suitable for fixing into, so you could foam around the box so it’s stuck in place
It is currently Thu Dec 05, 2024 2:12 am
