How to remove a Thermostatic shower tap
Bondma
by Bondma » Thu Jan 28, 2021 9:43 am
I need to remove a Shower Tap but not sure how, after turning of water supply. There are 4 screws but I think more needs to be done before I unscrew?
Re: How to remove a Thermostatic shower tap
by stoneyboy » Fri Jan 29, 2021 10:59 pm
Hi bondma
As a general guide you need to remove the centre knob, this should expose fixings for the outer dials. Remove these and you will then be able to get to the fixings for the outer shroud.
It is currently Mon Dec 23, 2024 12:16 pm
