Tricky pipe connection for chopped pipe
LeRouret
by LeRouret » Fri Feb 05, 2021 5:23 pm
Hello....it’s nice living in France...apart from the plumbing...I need to connect to the chopped pipe....the pipe in front will be removed...I think I can solder it...just...any hints or tips ?
I want to avoid concrete bashing...
Re: Tricky pipe connection for chopped pipe
by stoneyboy » Sat Feb 06, 2021 10:23 pm
Hi lerouret
Suggest you cut back the pipe to the hessian packing and use a compression fitting.
It is currently Wed Feb 05, 2025 11:59 am
