Is this dimmer transformer for a neon light safe?
Kmit
by Kmit » Sun Feb 07, 2021 7:05 pm
Is this dimmer transformer for a neon light safe, no cover and wires exposed, any advise would be appreciated
Re: Is this dimmer transformer for a neon light safe?
by Mr White » Sun Feb 07, 2021 9:44 pm
Where did you get it, and what are you proposing to use it for?
What do you mean by a "Dimmer transformer?"
It is not for a neon.
It is only 12v - 24v input and output.
It does appear to be meant to be mounted inside a housing.
Kmit
by Kmit » Sun Feb 07, 2021 10:00 pm
I’m using it to dim a neon sign no case was supplied and I don’t like how the wires are exposed - should I not use it just to be safe
by ericmark » Mon Feb 08, 2021 10:26 am
In the main neons are AC, and a neon sign can be a very high voltage, the device you show is DC looks like a step up inverter 12 to 24 volt and does not seem to have any control, so can't see how it would ever control a neon sign, so it seems you likely have described it wrong or have wrong device.
Kmit
by Kmit » Mon Feb 08, 2021 2:48 pm
Hi I’ve put up a new photo
The remote symbolises the neon sign
The sign company said it’s safe and it needs to be visible so the sign works
It is currently Tue Jan 28, 2025 3:22 am
