Wiring LED Batten fixture into plug with inline on/off switch
misterTii
by misterTii » Fri Feb 12, 2021 1:10 am
I'm looking at this- https://www.tlc-direct.co.uk/Products/RTWPLED2.html
How do I convert or wire this as a plug-in with an inline on/off switch?
The fixtures' wiring diagram on the info sheet shows only a live and neutral wire. No earth. Is this OK?
Would 2-core cable with 3amp fuse suffice? Or 3-core cable with the earth taped up somehow?
Seems like a simple question or job but so hard to find a definitive answer on the 'nets after a few hours looking.
Any advice greatly appreciated.
Re: Wiring LED Batten fixture into plug with inline on/off switch
by ericmark » Fri Feb 12, 2021 3:49 pm
The installation instructions clearly says "The light fitting is Class II and does not require an earth connection." so two core cable is fine.
misterTii
by misterTii » Fri Feb 12, 2021 10:29 pm
Ah yeah, you're right. That's dumb of me.
I guess that my plan sounds all OK then with the 2-core flex, 3amp fuse?
It is currently Fri Jan 10, 2025 3:25 pm
