Water flow pressure from all taps in home
paulsandi
by paulsandi » Sat Feb 13, 2021 2:28 pm
Should the water flow/presure from all taps in a home be the same or can they be different?
Re: Water flow pressure from all taps in home
by stoneyboy » Sat Feb 13, 2021 10:25 pm
Hi paulsandi
If you have a combi boiler flow from all taps should be about the same. If you have a tank fed system cold mains will be the highest, and a lower flow from other downstairs taps and even lower from upstairs taps.
It is currently Mon Dec 02, 2024 9:35 pm
