Recess roller blind tension gone
Lmin87
by Lmin87 » Sat Feb 13, 2021 7:32 pm
Recess roller blind fitted to patio doors. Over last few months, tension has gone and no longer staying down. Anyone had this experience or know how to solve it?
Re: Recess roller blind tension gone
by stoneyboy » Mon Feb 15, 2021 2:34 pm
Hi lmin87
I assume you are referring to the type of blind that you pull down and it locks in position, then a quick pull releases it.. if so you could try lightly spraying the mechanism with something like wd40. Failing this probably a new blind will be required.
It is currently Thu Dec 12, 2024 3:59 pm
