cornice
ash2004
cornice
by ash2004 » Mon Oct 01, 2007 8:59 pm
hi, can anyone tell me how to go about fitting cornice for kitchen cupboards corner units. How do i measure the angles, what tools do i need, is there a formula to measuring the length of cornice? AAAAAHHHHGH. PLEASE PLEASE PLEASE HELP
Many Thanks
gerryyy
by gerryyy » Mon Oct 08, 2007 10:57 pm
measure the length of cornice required, example 1000 mm unit, the length of cornice required would be 1000mm. then if u want to cut your joint, example 45 degree, you place your mark on the area of the cornice that comes into contact with the unit, then hold the cornice, as it would sit on the units, and cut with chopsaw..sounds complicated but it gets easier
Alan Palmer
by Alan Palmer » Sun Nov 18, 2007 10:52 am
Fitting Cornice, most respectable manufacturers give info sheet giving exact details of how they recommend cornice be fitted. Rule of thumb, after first piece make all pieces fit in the same way.
It is currently Sat Jan 04, 2025 4:20 am
