Ceiling rose reinstall; red sleeve on yellow wire?
6 posts   •   Page 1 of 1
misterTii
by misterTii » Mon Feb 22, 2021 2:31 pm
So I'm trying to remove and reinstall a new light fitting in bathroom - https://tinyurl.com/1ak6mx9v
Looking closer at the rose wiring it seems there is a red-sleeved yellow wire going into my L terminal. If this is the switch-wire why is it yellow? Why are there also 2 red-sleeved switch-wires; one black? Also note the two brown wires connected to the old light socket. Odd?
Rose
Rose
Rose close
Rose close
The new light fitting has standard L, N, & E terminals. I plan on wiring using the diagram below, except with 3-core flex with earth connection.
Is it a case of just matching the wiring exactly, into new terminals? I plan on just using 15A terminal connector strip bound with electrical tape after; does this sound OK?
new wiring
new wiring
Re: Ceiling rose reinstall; red sleeve on yellow wire?
by Mr White » Mon Feb 22, 2021 7:06 pm
There is no rule that says what colours must be used for what regarding lighting it is up to the individual doing the job what colours they actually use.
Your thinking regarding connecting your new lamp the same way it is now is correct, the only thing wrong is the connectors and insulation tape, you can now get "wago" connectors which are much better, you should also use a wago box.
misterTii
by misterTii » Tue Feb 23, 2021 10:47 am
Thanks for the info Mr. White. I'll look into the wago's.
chriscba
by chriscba » Tue Feb 23, 2021 1:25 pm
The yellow may be from a 3 core cable going to a extractor fan, there will be a permanent live, a switched live & a neutral going to a fan.
The black switch wire will be for the lamp
misterTii
by misterTii » Tue Feb 23, 2021 2:23 pm
Yes you are right, I realised after I posted that the extractor fan is wired to turn on when the light does.
I'll match the connections in the wago that should be here soon.
misterTii
by misterTii » Wed Feb 24, 2021 10:22 pm
Well I thought I would give an update as it may help others in future.
Wired up all fine, everything works :)
Hardest part was aligning mounting holes on the fitting to the joist in the ceiling.
Thanks everyone for the help
It is currently Fri Jan 10, 2025 3:43 pm
