Non Standard Tubular Latch (102mm or 4" backset)
Deeko99
by Deeko99 » Tue Feb 23, 2021 12:03 am
I'm changing some door handles on our solid wood internal doors and need new tubular latches.
Unfortunately the hole drilled in the door is non standard and I measure the back set distance (from spindle hole to edge of lock) at 102mm or 4". I have tried to find a tubular lock to fit this spec but all I can find is a back set of either 82 or 108mm.
Any advice on sourcing a tubular latches (are there such things as adjustable back sets) or is it new doors??
Thanks in advance!
Re: Non Standard Tubular Latch (102mm or 4" backset)
by stoneyboy » Tue Feb 23, 2021 10:29 pm
Hi deeko99
Do an internet search for “4 inch tubular door latch”.
Deeko99
by Deeko99 » Tue Feb 23, 2021 10:43 pm
Tried that
Hence the post. A 4" tubular latch does not mean a 4" backset!
by stoneyboy » Wed Feb 24, 2021 10:05 pm
Hi deeko99
How about one of these
https://www.e-hardware.co.uk/adjustable ... ckset.html
It is currently Wed Sep 18, 2024 2:12 pm
