Cold flat roof insulation and possibility of condensation
jhcbed
by jhcbed » Sat Feb 27, 2021 9:42 am
I have an existing bitumen flat roof maybe 30 years old but still serviceable. I suspect it must be a cold roof but has had no insulation on the underside. I have taken down the ceilings and there is no evidence of past condensation although it is impossible to adequately ventilate, as the joists run to a blank wall. I was intending to put in 100mm celotex, can this increase the possibility of condensation and sweating problems, logically to me it seems to make it less likely.
Re: Cold flat roof insulation and possibility of condensation
by stoneyboy » Sun Feb 28, 2021 10:02 pm
Hi jhcbed
By adding insulation you will reduce the temperature of the space above the insulation, this may mean that the space reaches dew point temperature so condensation will form.
jhcbed
by jhcbed » Mon Mar 01, 2021 10:21 am
Thank you I get the logic now
It is currently Mon Dec 02, 2024 2:44 pm
