External light cables hanging from external wall for lights
agtom
by agtom » Sat Feb 27, 2021 6:59 pm
I have just moved into a house that on the external walls at the rear of the house there are 2 holes in the masonry one has one looped cable coming from it the other has two looped cables protruding from the hole. How do I go about wiring two walls lights into the two locations?
Re: External light cables hanging from external wall for lights
by Mr White » Sun Feb 28, 2021 12:07 am
It is down to the person who installed it as to the configuration they were thinking of, so with that in mind it will need to be tested to find out what does what and if anything is connected
I can only suggest you get a competent person in to do the job for you.
It is currently Fri Jan 10, 2025 3:32 pm
