Immersion heater gasket
eastcoast
by eastcoast » Wed Mar 03, 2021 1:50 pm
When installing a new Immersion heater to a cylinder,
1) Should jointing compound be used with the fibre gasket?
2) Should PTFE tape be used on the thread?
Re: Immersion heater gasket
by stoneyboy » Thu Mar 04, 2021 9:41 pm
Hi eastcoast
1 - no 2 - no apply Vaseline to the threads in case you have to remove the heater at some time in the future. Regards S
eastcoast
by eastcoast » Fri Mar 05, 2021 10:23 am
[quote="stoneyboy"]Hi eastcoast
1 - no 2 - no apply Vaseline to the threads in case you have to remove the heater at some time in the future. Regards S[/quote]
Thank-you stoneboy. I did not have any Vaseline so I used copper slip. Regards.
It is currently Thu Oct 31, 2024 7:25 pm
