Bosch compact dishwasher terminates program at water inlet.
operator
by operator » Fri Mar 12, 2021 2:10 pm
Hello board members
I require your experience and advice regarding a used Bosch Compact Dishwasher model SKS51E18EU bought recently.
The previous owner of 5 years mentioned an issue that it doesn’t drain at the end of the program, so restarting a new program clears this issue.
After good results for 7-8 cycles its behavior changed.. The ordinary program sequence begins: Drainage > Emptying all water in the system > and then the inlet pump starts taking in water, after ~15 seconds of water going in, the "check water" indicator turns on, and the program ends with a long drainage. total of 3 minutes since program execution
I checked:
• Different configurations of the in/out tubes in different angles while running
• The inlet filter - was clean
• Drainage filter + unscrewed some piece to reach the cog-wheel of the pump making sure there are no obstructions
After looking online I found that for similar cases some concluded this might be the inlet valve, before ordering a replacement I need certainty that this is the solution, that’s why I require your help.
Thanks in advance!
Re: Bosch compact dishwasher terminates program at water inlet.
by stoneyboy » Sat Mar 13, 2021 10:16 pm
Hi operator
If you can hear water entering the machine and if you open the door after the 15sec and there is water in the bottom then it is not the inlet valve and you will have to look for a different issue.
It is currently Sat Nov 23, 2024 3:26 pm
