Shower mixer failure should I replace or fix?
jwicks64
by jwicks64 » Sat Mar 13, 2021 10:29 am
On bad advice our builder installed a no brand/cheap built in shower mixer in our new bathroom 5 years ago.
It has stopped working - and the water is almost impossible to adjust to the right temperature - and changes temp when other taps in the house are turned on/off.
We have been told that we should replace the whole thing - which would mean cutting open the wall etc. etc.
I can't even figure out how to access the cartridge.
Do we need to replace the whole unit or can the cartridge be cleaned/replaced?
Thanks for any advice.
Re: Shower mixer failure should I replace or fix?
by stoneyboy » Sun Mar 14, 2021 10:03 pm
Hi jwicks64
Remove the face plate to get access to the valve, you can then decide whether to repair or replace.
It is currently Mon Dec 23, 2024 12:10 pm
