main soil pipe map
ray
main soil pipe map
by ray » Tue Oct 02, 2007 1:47 pm
I am having difficulty finding the route/location of my main drains. I have dug a couple of holes but no sign.
Is it possible to get a map of the drains from local authorities?
by htg engineer » Thu Oct 04, 2007 9:36 pm
Not sure about getting maps, but your drains should run in straight lines. From house to main drain/manhole.
If you follow your soil stack from the toilet, to outside then walk in a straight line from this point directly to the manhole/main drain. This will more than likely be the route of the pipe.
WC
M A N H O L E
Also if you dig near the house the drains will probably be around 1.5 - 2ft down, the further you get towards the main drain the deeper it'll be. If you lift the manhole cover and look where the pipes enter the chamber it will probably be around 4ft down.
LCL
by LCL » Fri Oct 05, 2007 7:37 pm
Ray
You can get plans of public sewers from your waste water company, ie Thames Water, Southern Water etc. They charge about £35 I believe but only show public sewers. Your local building inspector may have an idea if any houses near you ahve had works carried out.
Hope this helps
LCL
It is currently Mon Dec 02, 2024 5:51 pm
