2 way 2 gang switch circuit issue as lights wont come on at same time
15 posts   •   Page 1 of 1
Keys
by Keys » Tue Mar 16, 2021 8:13 pm
Changed over what I thought was a like for like 2 gang light switch controlling 2 lights, now I cannot get both lights to come on at the same time
Wiring in switch box is 2 grey cables having 4 wires in each cable red,yellow,blue and earth,
Any help would be appreciated
Re: 2 way 2 gang switch circuit issue as lights wont come on at same time
by Mr White » Tue Mar 16, 2021 11:48 pm
You have obviously made an error in changing your light switch. Since there is no definitive colour scheme for light switches, the best solution would be to test everything to establish what it does, to that amends I suggest you get a competent person to visit site and diagnose and correct the error.
Keys
by Keys » Wed Mar 17, 2021 6:57 pm
What do you determine as a competent person
by Mr White » Thu Mar 18, 2021 10:25 am
A competent person is a person who has had enough training and experience or knowledge to either show you how the job should be done or to do the job for you. (Either way the job will be done safely.)
chriscba
by chriscba » Thu Mar 18, 2021 1:23 pm
Is this just 2 way switching, by the sound of your description, it looks like a centre switch out of three (intermediate switch) As there is no live switch wires(red & black)
if that is the case, you will have to look at the other switches where the cable ends are & connect the cables the same as that switch.
eg com to com L1 to L1 & L2 to L2
Keys
by Keys » Thu Mar 18, 2021 2:00 pm
Chriscba,
Yes thanks this is a 2 way switch with no other switches in the room this is working but only to get lights on independently cannot get bot on at the same time
Keys
by Keys » Thu Mar 18, 2021 5:04 pm
chriscba,
There is a Red live to the L terminal on one of the switches with the other Red going to the other L
L1 & L2 on both switches have the Blue & Yellow connected respectively on both switches.
Regards.
chriscba
by chriscba » Thu Mar 18, 2021 5:43 pm
Can you post some photos of the switch
Keys
by Keys » Thu Mar 18, 2021 6:17 pm
chriscba,
L1 & L2 on both switches have the Blue & Yellow connected respectively on both switches.With earth to plate, I have attached pics
Plate
Plate
Switch
Switch
chriscba
by chriscba » Thu Mar 18, 2021 6:49 pm
[quote="Keys"]Chriscba,
Yes thanks this is a 2 way switch with no other switches in the room this is working but only to get lights on independently cannot get bot on at the same time[/quote]
Keys
How can you have a 2 way switch in a room with only 1 switch?
the idea of 2 way switching is you turn the light on through one door & turn it off at another.
Do you mean a 2 gang switch, are there 2 lights operated by the 2 gang switch.
If that's the case, don't know why the switch has been wired in 3 core cable, are you sure there isn't another 2 core cable in there somewhere.
Keys
by Keys » Thu Mar 18, 2021 8:10 pm
Yes 2 lights operated by 2 gang switch no other switches/cables
chriscba
by chriscba » Thu Mar 18, 2021 8:26 pm
Your going have get someone in to look at it with some test gear, it’s impossible to say what you have done !!
Keys
by Keys » Thu Mar 18, 2021 8:37 pm
Yes that’s the next port of call especially when the lights are still working
chriscba
by chriscba » Sun Mar 21, 2021 1:50 pm
Are you sure there isn't a pull cord switch somewhere, or a switch in a corner that has been built over it.
Those 3 core cables have got to go to another switch somewhere.
Keys
by Keys » Sun Mar 21, 2021 2:20 pm
Thanks for the response but no there are no additional switches in the room just the one double switch with 2 grey 4 core cables
It is currently Fri Jan 10, 2025 3:29 pm
